Just nu känns det som om det här flyget skulle passa mig och mina behov.
EPP-CF FPV 1.8M Ultra-Strong R/C Plane platform.
.jpg)
Designed especially for FPV (First Person View) camera flight!
This is a true FPV plane thats easy to build and comes packed with common sense FPV must-haves such as rear mounted servos for the elevator and rudder to help counter balance the additional radio gear, rear servos can also be moved up and down the tails Carbon Fiber shaft to adjust CG. The narrow fuselage helps glide rates for longer flight times and yet it still has a large area for and aft of the CG to move the battery for better balancing when using heavy camera/Tx gear.
Rear mounted 10inch pusher-prop diameter motor-mount keeps motor and esc away from the camera to reduce noise.
EPP foam makes the plane very resistant to crashes and rough landings.
The EPP-FPV glider has a twin CF-Spar 1.8m wingspan for higher, longer flight times with a wide range of camera equipment.
The HobbyKing EPP-FPV has 4 channels (Ail, Rud, Elev, Thr) for agile performance and is reinforced with 2 CF spars on the main wing, a CF tail boom and CF elevator spar plus the ailerons have flat CF rods for stifness during fast turns or dives.
The mian wing can be removed easily for transport.
The HobbyKing EPP-FPV can take any number of batteries however we recomend a 2600~4500mAh 2S pack for long flight times and good CG balance.
Spec.
Fuselage length: 1150mm
WingSpan: 1800mm
ARF Weight: 800~1000g
Required.
Motor: 2217 1400kV Brushless outrunner
Propeller: 10x6 slow flyer
Battery: 11.1V 3S 1500~2200mah 20C
Servo: 4 x 9g
ESC: 40A
Your own TX & RX
http://www.hobbycity.com/hobbycity/stor ... duct=14465
