It is currently Wed 25 Feb 2026, 07:36
 Post subject: Nya flyg
PostPosted: Wed 02 May 2007, 22:25
Carl Golberg har släppt en ny Yak 54
http://www.carlgoldbergproducts.com/12043.htm
Video
http://www.carlgoldbergproducts.com/vid ... %20Yak.mpg
PostPosted: Sat 19 Jan 2008, 21:25
Embraer emb312F
http://www.nitroplanes.com/ememnigasarf1.html
New 2008 Nitro Models F-86 Sabre-140
http://www.nitroplanes.com/f-86-sabre-1 ... plane.html
Flying Cat 90
http://www.nitroplanes.com/flying-cat-p ... c-jet.html
F4J 40
http://www.nitroplanes.com/xx.html
EMBRAER 312F TUCANO
http://www.modellhobby.com/product_info ... ts_id=5018
Kommande modell från Östersunds Modellhobby
Douglas A-1H Skyraider
http://www.modellhobby.com/product_info ... ts_id=5559
Fiberglas kropp med trä/balsa vinge.
PostPosted: Sat 19 Jan 2008, 22:33
Length: 54"
Wingspan: 70.9"
Wing Area: 877 square inches
Wing Loading: 5.5kg, 12lbs.
Engine: 1.50 4-Cycle or 26CC gas.
Radio: 6 ch&9 servos.
Construction: Fiberglass fuse and balsa built -up wing
http://www.kmp.ca/product_info.php?cPat ... cts_id=178
PostPosted: Wed 30 Jan 2008, 19:11
Hittade en film på Douglas A-1H Skyraider ARF 30%
http://youtube.markacadey.net/video/sky ... _Tests_3_4
http://youtube.markacadey.net/video/sky ... _Skyraider
PostPosted: Sat 16 Feb 2008, 21:21
Ett litet och vackert flyg
SIAI Marchetti, spv 1530mm
ARF maskin byggd i balsa och plywood samt klädd med Oracover,
Spv: 1530nn, längd: 1230mm. flygvikt: 2495g, vingarea: 36,3dm2, RC: skev,höjd, sida, gas, motorkåpa i glasfiber, tillbehör ingår.
Lämplig motor: 2t 46-60, 4t 52-70.
http://www.modellhobby.com/product_info ... cts_id=555
