It is currently Tue 17 Mar 2026, 12:39
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: YT International Freestyle Adrenaline ARTF
PostPosted: Sun 25 Nov 2007, 10:28
Denna gång en lite mindre fågel.
Film http://www.rcfun.co.uk/avifiles/Dean_adrenalin.wmv
The Best ARTF " True Freestyle " Pattern Model.2 models in 1 perform extreme freestyle maneuvers with ease... Then flick the rates for precise F3A flying.
Feel the adrenaline running through your veins.
The Adrenaline was designed to fulfill the massive demand for a model that could excel at Pattern, Freestyle and 3d Flight. Large control surfaces, generous wing area and precision wing and tail sections all coupled with an overall light weight make for a model that is stunningly capable no matter what the piloting skills of the owner.
From the offset we wanted a model that gave outrageous performance but without compromising airframe strength. The adrenaline really a model that you can enjoy again and again! Designed in England with Ali Mashinchy who is the U.K. freestyle champion 2 years running, and undoubtedly one of Britain's finest display pilots.
This stunning aircraft has the major advantage of being one of the few models that you can perform some wild 3D maneuvers with on high rate and then with just the flick of the rate switch go ahead and fly a pattern routine as slow and precise as you like.
Specifications:
Wingspan: 68" Wing area: -sq.dm Flying weight: 3.7 kg Length: 68" Engine required:.61-1.08 two-stroke or .91-1.20 four-stroke
PostPosted: Sun 25 Nov 2007, 12:46
Menar du att du har köpt den oxå...! Eller visar du bara flyget i denna tråd :?:
PostPosted: Sun 25 Nov 2007, 13:37
Lägger man ut ett flyg under projekt vad betyder det Kamikaze :wink:
PostPosted: Sun 25 Nov 2007, 13:39
Öhhh. Sorry! Missade där..... :oops: :oops:
PostPosted: Sun 25 Nov 2007, 16:41
Den här fågeln är min julklapp till lillajul o den andra till stora jul :D
PostPosted: Sun 25 Nov 2007, 17:42
Lustigkurre :lol:
Kanske vi ska öppna en ny tråd med
1. Vad får du till lillajul
2. Vad får du till stora jul
3. Vem blev utan flyg
PostPosted: Mon 26 Nov 2007, 17:46
Lustigkurre :lol:
Sen så fyller jag ju år 2 veckor efter julafton :) Man kan ju alltid hoppas att det trillar in Yak 54 då :D
PostPosted: Mon 26 Nov 2007, 18:20
Allstå hur många flyg har du JS? tycker det bara ökar hela tiden :lol:
Tror man får komma ut o tryna lite nån kväll o se på alla vackra fåglar :)
Mikael Dahlström
Alias "Dawson"
PostPosted: Mon 26 Nov 2007, 19:19
Jag har tappat räkningen :) Men jag tror det är 10 eller 11 :?
Du är välkommen.
PostPosted: Sun 02 Dec 2007, 16:26
Ja då har det varit lillajul så man fick börja med Adrenaline :)
Alla roder limmade
Det är väldigt dålig passform på det mesta på flyget :evil:
Fortsättning följer...
PostPosted: Sun 02 Dec 2007, 19:20
PostPosted: Sun 02 Dec 2007, 19:24
Rätt snyggt flyg! Du har ju kommit långt också. Passformen... gick det
att skära / såga / fila rätt eller vart det galet? Och det var en himmelens
små hjul hörru :D
PostPosted: Sun 02 Dec 2007, 20:18
små hjul hörru :D
Det är bara o fila o såga lite så passar det :)
Hjulen är inte så små,det är landningsstället som är stoort.Hjulen är bra mycket större än calmaton´s.
Men nu finns det inte så mycket kvar o göra före jag får grejerna från Airpro
PostPosted: Mon 03 Dec 2007, 23:37
Gillar verkligen formen på den där fågeln! s*** snygg!!
PostPosted: Tue 04 Dec 2007, 08:44
Ja jag går i tron om att den ska ha samma flyg egenskaper som en Yak 54 :)
PostPosted: Wed 12 Dec 2007, 20:22
Nu börjar jag bli less på allt med det här flyget :(
Inte stämmer ritnigen heller :evil:
Så här säger ritningen.
Men det va 205/75mm
PostPosted: Wed 12 Dec 2007, 20:29
Här skall vajer in.
Här skall vajer ut och pågrund av en idiotisk ritning som inte stämmer så fick man ju börja lappa nya flyget :twisted:
Vingarna klara
PostPosted: Wed 12 Dec 2007, 21:24
Fyy fan va trist sånt är :shock: . Man förväntar sig faktiskt mer än så av tillverkarna :oops:
PostPosted: Mon 17 Dec 2007, 20:24
Om man tycker att man är på för gott humör så kan man ju gå o fixa på Adrenaline så är det goda humöret ganska snabbt borta :(
Servona till höjdrodren skall va precis mitt emot varandra o då tar dom ju i varandra,så det följde med bitar som man skall sätta under servona och det är ju inte vidare vackert.
PostPosted: Mon 17 Dec 2007, 23:15
Hitec HS-422 är väl ett lågt servo tex... kankse såna du borde köpt?
