It is currently Sun 19 Apr 2026, 11:04
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Vad man kan göra med en multicopter?
PostPosted: Mon 13 Jun 2016, 13:02
Varför inte bara ha roligt och filma.
PostPosted: Wed 03 Aug 2016, 21:25
Har fått grejer från denna firma i Australien...
Men kolla genom menyerna, finns huur många användningsområden som helst! :-D
http://www.riseabove.com.au/
Häromveckan var det en som jagar mårdhund i vass som tyckte det skulle vara skoj testa nån gång... det gav mig lite tankar om en quad med Turnigy HD 2K med livefeed för FPV... i Phantomskal.. hmhm... ;-)
PostPosted: Sun 14 Aug 2016, 13:38
Professionell fågelskrämma
http://www.riseabove.com.au/agstar-bird-scarer-payload
Bird Scarer Payload for AgStar Agriculture Drone. Our Bird Scarer Payload is based on the tried
and proven BirdGard system, which has been integrated and adapted for UAV usage. We have
also included an additional speaker for multi-directional sound which increases effectiveness.
PostPosted: Sun 14 Aug 2016, 13:40
Säd- eller fröspridare
http://www.riseabove.com.au/agstar-seed ... er-payload
Introducing the Seed/Feed Spreader Payload (small) for your AgStar Agriculture Drone.
Our Seed/Feed Spreader Payload is designed to autonomously spread seed or feed in a
predetermined location on your property.
This allows you to manually start/stop the feeder at any time from the pilot remote,
as well as make adjustments to the speed of the spreader.
This feeder can hold enough material to cover up to 1000 sq ft. We are currently
developing a large verison of this payload, which will be utilised on the AgStar Octocopter
System when released.
PostPosted: Sun 14 Aug 2016, 13:45
Internet-leverans-quad för att skicka grejer mellan dig o polarna via en app
http://www.riseabove.com.au/flytrex-sky-internet-drone
Flytrex Sky
The internet drone - designed to deliver
The first cloud connected drone powered by advanced 3G module
Ship and accept items from friends using the Flytrex Messenger app
Fly for fun with our Flytrex Pilot app
Easy to use, ready to fly out of the box
Fly manually or using autopilot
Powerful platform for hobbyists: Second battery support, dual piloting mode between 3G (mobile) and optional RC Transmitter and more
Built-in 3G tracker and logging via Flytrex service
Fly without range limitations using 3G network control
Note: Per CASA's aviation rules, we advise always flying your UAV within line of sight.
GoPro and FPV cameras not included, sold separately
PostPosted: Sun 14 Aug 2016, 13:50
Besprutning
http://www.riseabove.com.au/dji-agras-m ... ying-drone
The DJI Agras MG-1 is an octocopter designed for precision variable rate application of liquid pesticides,
fertilizers and herbicides, bringing new levels of efficiency and manageability to the agricultural sector.
It is exclusively available in Australia through Rise Above Custom Drone Solutions.
PostPosted: Sun 14 Aug 2016, 13:51
Finns en till fågelskrämma: http://www.riseabove.com.au/dji-matrice ... m-the-scar
PostPosted: Sun 14 Aug 2016, 14:00
Fågelskådning/övervakningsdrönare
Bird Control Drones
Don't be fooled by the copies; Rise Above are the original creators of the UAV Drone Bird Control System in Australia. Rise Above teamed up with BirdGard Australia, who have been producing high quality bird control products for years, and have integrated this technology into their UAV drones.
The result is an extremely effective, fully autonomous method of controlling bird populations in your farm, orchard or other. The effectiveness of these systems has been tested and proven, and we have numerous clients who are operating fleets of these machines on their properties to control bird populations.
With integrated waypoint control, you can preprogram flight paths for the system to follow, and sit back and watch while the drone does the hard work for you.
http://www.riseabove.com.au/industrial- ... ol-drones/
PostPosted: Sun 14 Aug 2016, 14:04
Samla in prover från luften
http://www.riseabove.com.au/air-quality ... e-5-sensor
The Scentroid DR1000 is a system developed to offer an innovative solution for the measurement of key environmental parameters, ie the quality of air we breathe. The Air Quality Sampling Unit consists of a flying laboratory to fit on a commercial drone (drone not included). It can be used to sample and analyze ambient air at heights of up to 150 meters above ground level that was previously impossible to accomplish. Air quality mapping, model verification, analysis of potentially dangerous sites are all made possible by this novel innovation.
PostPosted: Sun 14 Aug 2016, 14:09
Montera på en Parrot Sequoia Multispectra-kamera eller en för "NDVI Crop Monitoring"
http://www.riseabove.com.au/parrot-sequ ... -ndvi-crop
http://www.riseabove.com.au/micasense-r ... mera~39624
PostPosted: Sun 14 Aug 2016, 14:10
Ta vattenprover med en "drönare"
http://www.riseabove.com.au/agstar-precision-ag-drone
PostPosted: Thu 18 Aug 2016, 19:42
I Malmö flyger polisen med "drönare" nu med luftrummet avstängt för riktiga flyg (förutom ambulans o sånt).
De använder Saabs vidareutveckling på amerikanska Aerovironments Qube, en quad med 40 min flygtid.
Kamera och IR-sensorer mm. http://feber.se/samhalle/art/341796/pol ... re_drnare/
PostPosted: Sun 28 Aug 2016, 21:30
Kanske polis och brandkår skulle ha en drönare i standby som sticker iväg så fort ett larm går och flyger till platsen där larmet startat. Med videolänk så tar det ju inte länge få en bild på läget. Brinner det? Sticker inbrottstjuvarna iväg? Osv. Lättbyggt. Med tanke på att de går att bygga snabba och ändå ha lite flygtid så hinner de till platsen väldigt snabbt och kan vara där tills brandkår eller polis kommer på plats. 70 km/h är ju inte svårt, så på en halvtimme har den flugit raka vägen och kommit 35 kilometer, flygvägen. Placeras några såna ut på Åland så täcker man Åland i ett huj.
PostPosted: Mon 29 Aug 2016, 06:39
det krävs ju lite utrustning i en sån. Autonoma flygningar med kriftig videolänk, sattelit? stabilitet för hård vind, vattentäthet för regn osv. blir nog inte billigt att skaffa såna samt utbilda poliser att sköta dom. Vilka batterier ska användas ifall dom ska stå standby hela tiden?
Skicka ut Näse från station så slipper han till stranden var som helst på Åland på ca 20-25 minuter
PostPosted: Mon 29 Aug 2016, 11:09
Näse?
Iofs, har man en "Drönare" per station så hinner de snabbare fram de också.
Satellit för GPS ja, men videolänk finns det lösning för, antingen direkt (blir ju LOS om man har en högre mast) med en enkel länk, annars finns det repeater-lösningar om man inte vill använda så kraftiga sändare. Behöver inte vara lag-fri livefeed Med tracker och patch-antenn så kommer du flera mil idag.
LiPo's kan stå laddade en vecka. Cyklar dem så de kan storageladdas. Laddade acken kan vara i "drönarn", bara att plugga i acken och skick iväg på auto-mission till koordinaten och sen stå där i Loiter. För att spara ström kan man ställ in den att göra en Land (om man inte positionerat den över ett träd) eller RTL om det är närmare, standard APM-feature.
Man flyger inte om det är storm. Obs! Detta är ett komplement, inte huvudgrejen, det finns brandbilar och polisbilar för sånt. ;-)
Får väl göra om min APM-quad för att testa detta då. =)
Förfarande:
Utgångsläge:
Drönare står med acken på plats inomhus nånstans där det är lätt "slänga ut den" på marken.
Mission Planner kan ju va igång i bakgrunden på nån dator.
Masten med trackande patchantenn är ju alltid uppe. Även med telemetriantennen.
Sändaren kan vara inomhus nånstans, används ju inte, kan starta mission från MP.
När något händer:
Sändaren på.
Ut med drönaren.
Anslut acken.
Connect i MP.
Går in i plannern.
Laddar mission.
Nu borde drönarna ha hittat satelliter.
Korrigerar Loiter-platsen.
ARM.
Auto och iväg!
Antenntrackern känner av signalen och de har ju servo som styr mottagaren åt rätt håll.
Drönaren stiger upp till en säker höjd och pallrar iväg.
Väl på plats -> Loiter på koordinaten.
Videolänken tar emot bilden och visar den på en skärm.
Vill man kunna styra nåt mer så får man väl köra LRS.
Telemetrin däremot är väl knepigast, den är lost rätt snabbt.
Vad ser man i direktsändningen? Tja, bild rakt uppifrån är väl enklast. Sen går det väl att utveckla vidare.
Kan ju va givande att på stationen se lite vad som händer, vad vet jag.
Allt ovan går ju rätt så enkelt att bygga för korta sträckor.
Bara spånar! :roll:
PostPosted: Mon 29 Aug 2016, 12:01
Näse?
Andreas Näse. Motorcykelpolisen :)
PostPosted: Mon 29 Aug 2016, 12:03
Aha, jag trodde det var nån Vårdö-slang för Nisse. ;-)
Nå, han far bara i polisärenden. Som sagt, spånar. Gillar drönare och vill ha massor i luften. :-D
PostPosted: Mon 29 Aug 2016, 12:16
I get your point. Bara fördriver tiden med spekulationer. :)
PostPosted: Mon 29 Aug 2016, 13:24
Det är så man lär sig samt kommer på dumheter som man lär sig ännu mer på. ;-)
PostPosted: Sun 23 Oct 2016, 11:23
Flyga blod som Zipline gör med UAV-flyg i Rwanda sedan ett tag tillbaks... googla, youtube-sök.
