It is currently Thu 05 Feb 2026, 09:55
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: AAI RQ-7 Shadow FPV 2000mm Laser Cut Kit
PostPosted: Fri 06 May 2016, 09:54
Börjar dyka upp FPV-flyg med långa flygtider så sätt i ett 10000mAh 4S och du kan vara uppe länge.
Passligt flyg att bygga som kit nästa vinter :wink: having a range of over 100km and a 4 hour on-target loiter time.
In real life, the AAI RQ-7 Shadow is a battlefield UAV used by the armed forces of Australia, Italy, Sweden, the United States and others to provide a reconnaissance, surveillance and as a target acquisition platform.
Over 500 RQ-7 Shadows are in operational use throughout the world carrying electro-optic/infrared imaging sensors and having a range of over 100km and a 4 hour on-target loiter time. The specifications also required the UAV to be able to land in a sports field.
Our RQ-7 Shadow can't offer a 4 hour duration or a 100km range, but it is certainly a fantastic FPV platform with all of the highly practical features of the full size, including the aerodynamically proven inverted V tail, twin boom layout, center mounted pusher motor, fixed tricycle undercarriage and the huge central nacelle giving a clear view for your cameras and sensors.
For the scale enthusiasts among us the kit builds into quite an accurate representation of the full size Shadow and, at 2000mm wingspan the large scale enthusiasts won't be dissappointed either as this one is very nearly 1/2 scale!
The kit features a full set of components, laser cut from highest quality balsa and ply to make construction as fast, accurate and enjoyable as possible. A full accessory pack, leaving you with adhesives and covering material to provide in order to finish the model.
Features:
• Highly capable FPV platform
• Accurate laser cut parts
• Quality balsa and plywood construction
• Full accessory pack
• Easy to follow manual
• Large payload capacity
• Landing gear included
Specs:
Wingspan: 2000mm
Length: 1630mm
Flying weight: 3200~4000g
Radio: 4 channel minimum
Motor: 2820 900-1100KV brushless outrunner
ESC: 60A
Propeller: 12 x 6
Required:
4 Channel RC gear (minimum)
2 x 17g servos
2 x standard servos
5000-10000mAh 4S LiPoly battery
2820 900-1100KV brushless motor
60A ESC w/BEC
Covering
Adhesives
Choice of FPV equipment (optional)
http://www.hobbyking.com/hobbyking/stor ... t_Kit.html
 Post subject: Re: AAI RQ-7 Shadow FPV 2000mm Laser Cut Kit
PostPosted: Fri 06 May 2016, 09:58
Not a Drone for Child : US RQ-7 Shadow in Action
PostPosted: Fri 06 May 2016, 10:04
RCGroups forum http://www.rcgroups.com/forums/showthread.php?t=2648518
PostPosted: Fri 06 May 2016, 10:06
Hur många kit ska vi ta hem till vintern :wink:
PostPosted: Fri 06 May 2016, 11:34
Fränt. Köp den, bygg den å så flyger vi i lag med Skua
PostPosted: Fri 06 May 2016, 11:55
Woah! Den där har jag vart sugen på tidigare. =) MEN... då var det "originalet" (läs: också kopia på riktiga RQ-7'an, men ARF) som är 2,6 m om jag minns rätt (fanns en på 4,5 eller nåt också om man vill vara värre)... det där är ju en HobbyKing äuhm... :lol:
2000 mm är inte såå stort trots allt. Vet inte hur den ska kunna flyga så länge när andra knappt klarar 2h i den storleken och då är de gjorda i EPO.
Originalet är väl inte så stor iofs: https://s-media-cache-ak0.pinimg.com/73 ... 1cb143.jpg
EDIT: Här finns dom http://www.fpvmodel.com/fpv-airplanes_f ... n_c86.html
PostPosted: Sat 07 May 2016, 23:50
Läste texten lite noggrannare...
"Our RQ-7 Shadow can't offer a 4 hour duration or a 100km range, but it is certainly a fantastic FPV platform"
Haha... jaså det var originalet som tex militären använder som kan flyga 4 timmar. ;-)
Skulle vara skoj bygga en större än Majan (som är 2200 mm), men vad ska man ha den till? Visserligen skoj att testa en massa med. Kanske ännu bättre övervaknings/spaningsflyg?!
Men om man ska skaffa nåt nytt utöver Maja som är större... så får man börja fundera på arbeta tillsammans med nån.
Får väl sikta på 2,6 meter då...
- Swallow 2645 mm 690USD http://www.fpvmodel.com/swallow-electri ... g1042.html
- Hugin II 2600 mm 499USD http://www.fpvmodel.com/hugin-ii-electr ... m_g46.html
- Mjolnir Shark 2620 mm 2075USD http://www.fpvmodel.com/mjolnir-shark-u ... m_g45.html
- Mini Mugin 2600 mm 1100USD http://www.fpvmodel.com/mini-mugin-2-6m ... w_g15.html
Eller 3m???
- New Mugin V-Tail 3000 mm 1908USD http://www.fpvmodel.com/new-mugin-3m-ua ... m_g20.html
- New Mugin H-Tail 3000 mm 1973USD http://www.fpvmodel.com/new-mugin-3m-pl ... m_g14.html
Eller när man ändå håller på... 4,5m?
- Super Huge Mugin 4450 mm 3689USD http://www.fpvmodel.com/super-huge-mugi ... _g628.html
- New Mugin Plus 4500 mm 2399USD http://www.fpvmodel.com/new-mugin-plus- ... _g962.html
:mrgreen:
PostPosted: Sun 08 May 2016, 00:14
Hobbyking RQ-7 Shadow Build Pt2
PostPosted: Sun 08 May 2016, 00:16
Hobbyking RQ-7 Shadow Build Pt3
PostPosted: Sun 08 May 2016, 00:18
Hobbyking RQ-7 Shadow Build Pt4
PostPosted: Sun 08 May 2016, 00:35
Den verkar vara väldigt lättbyggd.
De kallar den FPV-kärra, men den har inget byggt för det?!
Flyger den bra då? ;-)
Skulle nog va kul bygga.
Hade jag inte haft så förbannat med flyg redan så...
Och vad skulle man ha den till?
Inte FPV, det finns så mycket annat som är bättre för det ändamålet.
Men kanske nåt att sätta denna i: https://www.youtube.com/watch?v=4RDh9GOsXeE
PostPosted: Sun 15 May 2016, 13:19
Nå, Mr X, vad hade du för planer?
Kollat upp nåt om flygegenskaper och vikt, last osv?
Kanske man skulle skala upp den till ... 3 m?
PostPosted: Sun 29 May 2016, 19:06
Hobbyking RQ-7 Shadow Build Pt5
Hobbyking RQ-7 Shadow Build Pt6
PostPosted: Sun 05 Jun 2016, 23:29
Hobbyking RQ-7 Shadow Build Pt7
PostPosted: Mon 06 Jun 2016, 08:21
Börjar va jobbigt nu. Måste ju få Skua klar för bövelen. Får ju såna habegär, den där 2,6 meters Mini Mugin sku duga bra :) Undrar hur mycket skoj man sku kunna klämma in i den..... Går säkert ett par tusingar om man riktigt vill :)
PostPosted: Mon 06 Jun 2016, 19:02
Joo, det är riktigt skoj bygga såna här flyg med massa kejkor.
Mini Mugin är väl till och med bensindriven, helt annan nivå. =)
Frågan är vad man ska göra med flyget...
PostPosted: Mon 06 Jun 2016, 20:51
Skick de till kökar å ta en bild på kyrkan å hem igen via Grisslehamn?
PostPosted: Mon 06 Jun 2016, 21:11
Ja Kökar hade jag ju glömt...
PostPosted: Sat 11 Jun 2016, 15:04
Den är nu på 65.95 vilket är ett lägre pris än tidigare.
