It is currently Fri 27 Mar 2026, 04:52
Post new topic Reply to topic  [ 108 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Lågfrekvent RC länk
PostPosted: Sat 12 Dec 2015, 10:26
Var går egentligen gränsen för hur lång räckvidd man vill ha eller är nöjd med. Eller vill man bara ha stark signal i skogen vid fpvflygning?
Jag har kikat på olika alternativ med detta och förmodligen beställs så småningom ett Dragonlinkpaket.
Finns fina paket på http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=11_189_190&products_id=994
One of the most popular long range UHF R/C systems, now with the legendary Ready Made RC, LLC support to back it up!
Flawless R/C control anywhere, any distance, any time for Copters, Planes, Cars and Robots... Imagine flying FPV without ever having to worry about failsafes, glitches, Interference in the city, or from surrounding objects. The Dragon Link system just works, no hassles, no extra steps needed, just turn it on and fly. Even though the Dragon Link system will typically have a range of 40 KM with stock antennas, you do not need to be a long range flyer to get the best benefits of this system. The Dragon Link is incredibly resistant to interference, and if you fly a copter in the city at short distances, this is the solution for you. Dragon Link will give you flawless copter control without ever having to worry about interference from buildings or city environments again.
The Dragon Link complete system includes everything you need for long range and high performance RC control, there is nothing additional to purchase. Just order the complete system, and chose the correct options above for your RC Transmitter connection cables and airplane antenna options. NOTE: The Dragon Link system is for RC control only, it does not transmit or affect video transmission in any way.
 Post subject: Re: Lågfrekvent RC länk
PostPosted: Sat 12 Dec 2015, 10:38
Sen finns Arkbird. budgetvarianten för runt hundringen. Finns mycket av denna på tuben och vissa är nöjda medans hårdkritikerna med ingengörsutbildning inte riktigt är impade över finishen på korten i fråga, funktionen finns där men lödningar och detaljer kunde varit snyggare.
Denna finns lite överallt men tex: http://www.aliexpress.com/store/product ... 78296.html
Specs:
Dimensions (Transmitter): 73 x 70 x 24mm
Antenna Length (Transmitter): 201mm
Weight: (Transmitter with Antenna): 116g
Dimensions (Receiver): 44 x 26 x 10.5mm
Antenna Length (Receiver): 155mm
Weight (Receiver with Antenna): 26g
Frequency: 433MHz
Radio Output: 100mw-1400mw
Power Input (Transmitter): 2-3s (7-12.6v)
Power Input (Receiver): 2-3s (4-12v)
Peak Current (Transmitter): 400mA @ 12v
Peak Current (Receiver): 120mA @ 5v
Range: Full Range
Arkbird-433MHz-10-Channel-FHSS-UHF-Module-Repeater-Station-with-Receiver.jpg_200x200.jpg
Arkbird-433MHz-10-Channel-FHSS-UHF-Module-Repeater-Station-with-Receiver.jpg_200x200.jpg [ 11.35 KiB | Viewed 17650 times ]
PostPosted: Sat 12 Dec 2015, 10:44
Vidare har vi Immersions EZUHF serie som kostar lite mer men fortfarande mänskliga summor.
Finns också hos readymaderc: http://www.readymaderc.com/store/index. ... cts_id=926
Specs:
-Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
-433MHz/70cm Ham band operation
-GFSK modulation
-600mW (~28dBm) output power
-Direct head-tracker input, adding head-tracker compatibility to most radios
-Power switch, boost power when at long range
-Standard SMA antenna connector, compatibility with 70cm antennas
-Flexible buffered, AC-coupled, PPM input, ensures compatibility with 3.3v thru 9.6v PPM levels
-Standard USB port (Mini-A) for firmware upgrades, and system configuration
-Single pushbutton learning of failsafe positions
-Binding function, which allows binding Single Tx->Rx, Multi Tx->Rx, and Single Tx->Multi Rx
-Mates with 8 channel, and 4 channel EzUHF receivers
-Power sourced directly from the R/C Tx (Futaba), or optional DC power jack
-Built in receiver, for future expansion
-Custom extruded brushed aluminum enclosure
PostPosted: Sat 12 Dec 2015, 14:26
Detta är väl lite väl men lagom ball längd på denna iaf :)
Flugen med DragonLink
PostPosted: Sat 12 Dec 2015, 15:56
Bra tråd!
För att komma igång inför ett inköp behöver jag veta...
1. Vilka frekvenser används?
2. Vilka tillverkare finns det?
3. Vilken tillverkare "is teh shit"? Och vilken kommer på andra plats?
Och sen...
4. Vad ska man ha på ett stort flyg för att få räckvidd?
5. Vad ska man ha på en lite 250-quad för att få genomträning genom skogen?
6. Vilka sändare fungerar de till? Byter man modulen bara?
PostPosted: Sat 12 Dec 2015, 17:31
Bra tråd!
Och sen...
Frekvenser? Jag har hittat en tillverkare som säger att dom går mellan 433-440 MHZ
Tillverkare finns väl säkert lika många som 2,4 ghz radion....
The shit? Säg de. Immersion skulle jag spontant gissa medans de flesta på tuben iaf verkar använda DragonLink
Till flyg för lång räckvidd verkar Dragonlinken som jag visade längre upp visa på flygningar på runt 40KM och mer ibland...
Jag skulle nog välja ExUHF:s lilla 18 grams 8 kanalare för 250 quad.
http://hobbywireless.com/immersionrc-lo ... 1f3343a5c3
Cable Types/Compatibility
Taranis, Turnigy, And Older RC Transmitters with removable RF module
This cable connects the Dragon Link transmitter to ALL RC transmitters that have a removable RF module. It has standard header pins that you connect to the RF module pins which are exposed once you remove the RF module from the back of your R/C transmitter. This is a very quick and easy way to connect your Dragon Link to your RC/ transmitter, as it provides both PPM and power, and is a one cable connection. It is not required to open the RC transmitter to connect via this cable.
NOTE: This cable will NOT work with the New High End Futabas that have a double row of very Tiny Pins when the RF module is used.
Spectrum, JR, Hitec, and Other 2.4 GHZ Transmitters with no removable RF module
This cable has a small " Mini Audio " type plug that plugs into the DSC or Trainer Port output of modern RC transmitters. This is compatible with ALL Spectrum, and JR RC transmitters regardless of model. This cable is a little harder to connect as the DSC / Trainer ports of this type do NOT supply power to the Dragon Link. This cable also includes a JST power connector that must be connected to an external 2-4 cell LiPo or 5 to 18 volts, for an installation that can be done without opening the RC transmitter.
Note: You can connect to the internal switched power of the RC transmitter, but this will require opening the transmitter and some basic soldering skills.
Futaba Square Trainer Port Connector
This is the quickest and easiest way to connect the Dragon Link Transmitter to any Futaba RC transmitter that has the standard Futaba Square type trainer port. Simply Plug in, activate the trainer port in your Futaba transmitter's computer menu, and it will work. We use a genuine high quality Futaba plug, not the cheap chinese ones, for reliable connection and operation.
The Dragon Link is made in the USA and fully guaranteed.
PostPosted: Sat 12 Dec 2015, 18:44
Vilka effekter använder man för 40km och för 250-quads skogsrace?
PostPosted: Sat 12 Dec 2015, 20:49
Säg de. Standard jag hittar för de som påstår sig räcka 40km ligger runt 500-600mw
Arkbird är tydligen justerbar mellan 100-1400mw och sen har Sherrer en 8w sändarförstärkare...
PostPosted: Sat 12 Dec 2015, 21:21
Kollat en massa reviews och det verkar som de som testat Immersions EzUhf är nöjdare med den än Dragonlink.
PostPosted: Sat 12 Dec 2015, 21:29
För 250 alltså?
PostPosted: Sat 12 Dec 2015, 21:31
För 250 alltså?
Överlag tydligen
PostPosted: Sat 12 Dec 2015, 21:49
Det är som du säger just de två tillverkarna man läst mest om.
Själva mottagaren är ju en sak, men sen är det ju det där med antenner, de kan vara rätt stora/långa.
ImmersionRC EZUHF
Verkar vara rätt dyra, kostar ju typ 300€.
ImmersionRC-sändare: Bara hittat en modell?!
1. ImmersionRC EZUHF 600mW Transmitter http://www.readymaderc.com/store/index. ... dd98e7cead
Och dessa mottagare:
1. ImmersionRC EZUHF 4 Channel Receiver http://www.readymaderc.com/store/index. ... dd98e7cead
2. ImmersionRC EZUHF 8 Channel Lite Receiver http://www.readymaderc.com/store/index. ... dd98e7cead
3. ImmersionRC EZUHF 8 Channel Diversity Receiver http://www.readymaderc.com/store/index. ... dd98e7cead
Futaba-kabel
Hoppeligen kommer det antenner med?!
En undran, är det bara mottagaren som är en diversity-mottagare? Precis som det iofs är med Futaba-sändare.
En undran till, måste man ha 600mW-sändare för att flyga lite FPV-racing i en skog max några hundra meter bort?
Kör folk verkligen dessa grejer i sina quads eller finns det andra tillräckliga ImmersionRC-grejer? Andra tillverkare kanske?
PostPosted: Sat 12 Dec 2015, 23:24
ImmersionRC EZUHF
Futaba-kabel
Kollade lite på sändaren. Du har ju en brytare på den... Lo=200mW Hi=500mW
Infon:
Dimensions: L=85mm x W=70mm x H=25mm
Weight: 120g
R/C Channels: Maximum of 12 (future upgrade to 16)
RF Impedance: 50 ohms
Power Output: 500mW (27dBm), with 200mW low-power mode
Modulation: GFSK
Hopping: 20 of 40 slots, 2MHz, or 20MHz frequency spread (Extreme Hopping)
Frequency Band (Std. Firmware): 431-433MHz, 433-435MHz, 435-437MHz, 436-438MHz, 430-450MHz (Extreme Hopping)
Frequency Band (UK Firmware): 459MHz
Power Requirements: 9-12v
Power Consumption: 250mA
PostPosted: Sun 13 Dec 2015, 20:02
Nu har jag läst på lite och har konstaterat att det är ImmersionRC EzUHF jag ska ha. =)
Det verkar cirkulera bland TBS, FatShark, Futaba osv, dvs såna märken jag använder.
Så Uffe, om du tänker beställa från RMRC, säg till så jag hakar på, om OK?
PostPosted: Mon 14 Dec 2015, 20:38
Hittade ett till fabrikat som kanske tål att tittas på. TBS Crossfire
http://team-blacksheep.com/products/prod:crossfire_tx
PostPosted: Mon 14 Dec 2015, 21:45
Mjo, men frekvens på 868MHz eller 915MHz. 868 godkänd i EU, "står det", undrar jag... kan det va så?
Drar sjuka mängder ström jämfört med de andra, men det är ju trots allt på marken. Även vid 10mW.
Tung stor mottagare, inget för 250-quad iaf...
Men nog verkar den rätt frän ändå med dess funktioner. Se filmen.
En annan grej jag såg var att den 250-quad som visas i filmen, med risk för att bli lätt distraherad på slutet, hur som, de har stackat ESCarna på varann under styrkortet. Smart! :-D Mindre kablage.
PostPosted: Wed 16 Dec 2015, 22:16
Japp hittade listan tillslut. 199 sidor listade frekvenser med beskrivning om krav och sändarbegränsningar :)
https://www.viestintavirasto.fi/attachm ... 2.2015.pdf
PostPosted: Thu 17 Dec 2015, 06:48
433.050 - 434.790 MHz
Utrustningar befriade från kravet på tillstånd. Se Kommunikationsverkets föreskrift 15. Strålningseffekten max. 25 mW ERP. Standard EN 300 220-1.
Duty faktor < 10 %, träder i kraft 1.4.2003. SRD-rekommendation ERC/REC/70-03.
Europeiska kommissionens beslut 2006/771/EG, den gällande tekniska bilagan är beslut 2013/752/EU.
Jamen de e ju nästan samma som EzUhf?
PostPosted: Thu 17 Dec 2015, 06:55
Och Crossfire
868.600 - 868.700 MHz
Övervaknings- och larmapparater med låg effekt samt trygghetstelefoner.
Se Kommunikationsverkets föreskrift 15. Strålningseffekt max. 10 mW ERP.
Duty faktor < 1 %.
No e de godkänt alltid. Bara sändareffekten här också som här också kan diskuteras.
PostPosted: Wed 23 Dec 2015, 17:45
Crossfire 10mW. Hur funkar det med Long Range System? =)
Vilket ska man välja?
ImmersionRC är klockrent. Men CrossFire verkar bra.
Vad kostar de olika delarna och var ska man köpa ifrån?
