It is currently Fri 27 Mar 2026, 05:40
 Post subject: Fatshark Dominator HD2
PostPosted: Tue 17 Nov 2015, 17:53
Har väntat länge på dessa glasögon men nu är dom köpta.
Bara paketet kommer så blir det säkert några bilder.
New FatShark Dominator HD2 FPV Goggles Review - Part 1
New FatShark Dominator HD2 FPV Goggles Review - Part 2
 Post subject: Re: Fatshark Dominator HD2
PostPosted: Tue 17 Nov 2015, 21:55
Väldigt coola! Avis!!! ;-)
Bara en massa filmer. =)
Har du inte en massa specs då?
Och vad ingår i de du köpt?
PostPosted: Tue 17 Nov 2015, 21:59
Vi får se vad som finns i paketet.
PostPosted: Tue 17 Nov 2015, 22:06
Ha! Får väl vänta då. =) Gah!
Får titta sen hur bilden är... slutar väl med att man samma dag ... *klick*
PostPosted: Tue 17 Nov 2015, 22:08
Va va skillnaden mellan HDV2 och "vanliga" V3?
Är det bara upplösningen?
HD = 800x600 = kräver bättre videolänk = risk för mer brus... men dagens grejer ska väl räcka till.
PostPosted: Tue 17 Nov 2015, 22:27
V3 har 16:9 widescreen och passar bättre till Phantom
PostPosted: Tue 17 Nov 2015, 22:45
Dominator HD has been the world’s best FPV goggle for a number of years. The Dominator series of FPV goggles is back with the HD2 incorporating subtle improvements to ensure its continued dominance as the world’s premier FPV goggle.
The HD2’s new hybrid plastic/glass optical engine not only has improved eye relief and alignment tolerance, it has also increased the FOV to a massive 50 degrees! DVR can now be switched on the fly between PAL and NTSC formats and files are closed if power is interrupted. Digital pilots will appreciate the beefed up mini high definition media interface port for solid mechanical connections to digital receivers. A new 1800 mAh battery provides hours of flight time and the pack level can be verified on the integrated LED power bar. The Dominator HD2 delivers top FPV performance in a small, portable package.
Features:
• Large Field of View
• Integrated Analog DVR (no high definition media interface recording)
• Failsafe Video Recording (no files lost during power interruptions)
• High definition media interface720p Support
• Modular Head Tracker Bay
• Modular Receiver Bay
Specifications:
FOV: 50°Diagonal
IPD Range: 59-69mm (adjustable)
Display: SVGA 800 X 600
Supports: Side/Side 3D
Format: NTSC/PAL Auto Selecting
Power: DC in: 7-13V (2S/3S)
Power Consumption: 4W
Included:
Dominator HD2 Headset with fan-equipped faceplate
Zipper Case
7.4V, 1800mAh Battery with LED Indicator
AV Cable
Mini to Mini high definition media interface cable
(Includes Mini to Micro, Mini to Standard high definition media interface adapters)
PostPosted: Tue 17 Nov 2015, 22:51
Once you’ve been bitten by this new Shark you’ll never go back.
PostPosted: Wed 18 Nov 2015, 21:42
Så du menar att jag inte borde prova några andra för då måste jag köpa nytt? ;-)
PostPosted: Sun 22 Nov 2015, 19:05
Tror många tvekar att börja med FPV för utrustningen är inte direkt billig.
Känns skönt att detta hinder är över och man kan börja njuta av FPV på riktigt.
PostPosted: Sun 22 Nov 2015, 20:40
FPV kan nog va rätt dyrt. Man kan jämföra upplevelsen med TV. Sitta nära en liten 14" gammaldags husvagns-TV där bilden knappt får rum eller 60" platt-TV. Det kostar om man vill ha det lite bättre. Det mesta fungerar, men upplevelsen är helt olika.
Det är nog runt 1000€ man får satsa om man ska ha bra goggles + groundstation + videosändare och antenner samt kameror. Om det ens räcker. Men det går alltid att köpa billigare eller beggat.
Men som du säger, sen har man grejerna flera år. Jag är fortfarande nöjd med mina goggles som jag haft sedan 2010.
PostPosted: Sun 29 Nov 2015, 21:42
Har du fått dem? Har bara hört gott om dem.
PostPosted: Sun 29 Nov 2015, 21:48
Väntar på dom än
PostPosted: Mon 30 Nov 2015, 19:25
Nu sitter man med en låda som innehåller DominatorHD2; The world’s best FPV goggle. :roll:
PostPosted: Tue 01 Dec 2015, 07:46
:shock: :D :wink:
PostPosted: Tue 01 Dec 2015, 11:43
:shock: :D :wink:
DominatorHD2
PostPosted: Tue 01 Dec 2015, 11:49
I lådan hittade jag ett par Fat Shark kalsonger och en ask :D
Skönt med nya kalsonger när man ska flyga FPV.
PostPosted: Tue 01 Dec 2015, 12:17
Text på baksidan och en haj på framsidan så nu är man klar att bita ifrån :D
PostPosted: Tue 01 Dec 2015, 12:20
Lite mera prylar i lådan förutom kalsongerna.
PostPosted: Tue 01 Dec 2015, 12:42
