It is currently Mon 30 Mar 2026, 22:03
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: Såld: Turnigy Accucel-8 150W 7A Balancer/Charger
PostPosted: Thu 31 Jul 2014, 09:48
Turnigy Accucel-8 150W 7A Balancer/Charger 30€
The Accucel-8150 is a Lipoly/LiFe battery charging workhorse.
Capable of handling up to 8S, 7A or a maximum of 150W charging current plus it balances and discharges packs which is critical for keeping your expensive batteries in perfect condition.
This charger has a 12v input and can be used with a mains 12v power supply or your car battery when at the field.
TURNIGY Accucel chargers are built with quality components and produced in robotic pick-n-place SMT technology machines to produce a reliable and accurate charger.
Spec.
Operating voltage range: 11.0~18.0Volt
Circuit power: max. 150W
Charge current range: 0.1~7.0A
Discharge current range: 0.1~5.0A
NiCd/NiMH battery cell count: 1~27 cells
Lithium bettery cell count: 1~8 Series
Pb battery voltage: 2 to 36V
Weight: 625g
Dimensions: 170X125X35mm
12V Note: Power supply not included.
 Post subject: Re: Säljes: Turnigy Accucel-8 150W 7A Balancer/Charger
PostPosted: Thu 31 Jul 2014, 10:13
Köper den jag...
PostPosted: Thu 31 Jul 2014, 10:18
Köper den jag...
OK såld till dig
PostPosted: Thu 31 Jul 2014, 10:24
Köper den jag...
OK såld till dig
Prima. Jag hör av mig när jag har vägarna förbi :)
 Post subject: Re: Såld: Turnigy Accucel-8 150W 7A Balancer/Charger
PostPosted: Thu 31 Jul 2014, 10:47
ok
PostPosted: Fri 01 Aug 2014, 12:34
Slå en pling före för min semester börjar på måndag.
PostPosted: Fri 01 Aug 2014, 12:48
Ålrajt. Har du för avsikt att lämna ön under semestern?
PostPosted: Fri 01 Aug 2014, 15:00
Troligen inte vad jag vet just nu.
PostPosted: Thu 07 Aug 2014, 16:45
Om jag sku komma via på Månda? Tänkte komma idag men var tvunget att hämta dotra som låg me feber på dagis...
PostPosted: Thu 07 Aug 2014, 18:15
Måndag blir bra
