It is currently Fri 27 Mar 2026, 06:50
Post new topic Reply to topic  [ 216 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: Ny 2.4GHz? Vad ska man ta?
PostPosted: Mon 03 Oct 2011, 09:14
"Robbe" Futaba Telemetrie-System 2,4 GHz på tyska.
http://reinerfuchs.re.funpic.de/PDF/FAS ... 282%29.pdf
PostPosted: Fri 14 Oct 2011, 18:33
Futaba kommer med en ny radio som visades upp på Tokyo Model Show.
Futaba 8J använder S-FHSS systemet (så den fungerar inte med FASST eller det nya FASSTest 2.4 Ghz systemet.)
En radio med mera finesser än deras nuvarande 6J verkar det som.
Toppmodellen 18MZ suktar man efter som också visades upp på Tokyo Model Show.
http://www.rcmania.hk/2011/10/16916
JR hade också några nyheter på mässan.
http://www.rcmania.hk/2011/10/16886
PostPosted: Sat 04 Feb 2012, 00:46
Nya lätta små mottagare till en billig peng.
Äntligen är dom här till Futaba.
PostPosted: Fri 24 Feb 2012, 10:49
Spektrum DX18
Kommer till sommaren
50 Model Memory
Built-In Telemetry with Vibe Alerts
Extensive Airplane, Helicopter and Sailplane Programming
Timer Throttle or Switch Start
Region Settings for Global Compliance
16 Programmable Mixes
Flap Delay and Elevator Compensation
10 Airplane Wing Types
6 Airplane Tail Types
4 Airplane and Heli Flight Modes
Dual Rates and Expo
Active Gyro Trim
7-Point Heli Throttle Curve
7-Point Heli Pitch Curve
7-Point Heli Tail Curve
6 Swash Plate Types
Swash Plate Timing
5 Sailplane Wing Types
3 Sailplane Tail Types
10 Sailplane Flight Modes
Global Charging System
PostPosted: Sat 25 Feb 2012, 12:33
Hitec släpper HTS-iView till Eurora 9
Explore world of Hitec’s 2.4GHz telemetry on your iPod touch / iPhone and iPad with HTS-iVIEW. The HTS-iVIEW is a telemetry interface between Hitec’s AFHSS 2.4GHz radios and youriPod touch/iPhone/iPad. Through HTS-iVIEW, you can monitor, save and replay all telemetry information on your Apple devices and set up user’s warning condition
PostPosted: Sat 25 Feb 2012, 14:53
Tekniken skenar :D
PostPosted: Wed 29 Feb 2012, 21:50
Ny Futaba Mottagare R6108SB 2.4GHz FASST S.Bus high-voltage
R6208SB • S.Bus kompatibel 2.4GHz FASST™ mottagare
En ny "high-voltage" FASST™ mottagare med S.Bus.
R6208SB erbjuder full räckvidd med "dual antenna diversity" och kan användas i alla flyg applikationer. R6208SB erbjuder dessutom high-speed mode och normal mode.
I high-speed mode krävs Futaba digitalservon, Futaba BLS servon eller Futaba S.Bus servon.
R6208SB fungerar tillsammans med:
- T8FG(S) 2.4GHz (i 8ch mode)
- TM8 modul (i 8ch mode)
- T10CG 2.4GHz (i 10ch mode)
- TM1 modul (i 10ch mode)
- TM14 modul (i multi-ch mode)
- Kanaler: 8 st utan att använda S.Bus. Med S.Bus har man så många kanaler som sändaren erbjuder...
- Storlek: 24.9 x 47.3 x 14.3 mm
- Vikt: 13.8 g
- Drivspänning: 3.7-7.4V (med voltmfång: 3.5-8.4V)
PostPosted: Tue 03 Apr 2012, 20:53
Det nya är AnyLink för att flyga små PNP kärror
There's a new way to fly more aircraft with the same transmitter you have now: Transmitter-Ready Aircraft. Transmitter-Ready aircraft are just that: aircraft you can fly with virtually any flight radio. They're prebuilt and finished for your convenience. They arrive with onboard gear installed and a LiPo battery and charger ready for use. And they offer a range of flying choices that include WWI bipes, a WWII fighter, civilian classics, sport planes, scale planes, a trainer and more. Best of all, you don't need to buy an expensive new radio system to fly them. You can fly all the Tx-R aircraft you like with nothing more than your favorite transmitter — and the AnyLink Radio Adapter.
Works with these popular transmitter brands: Futaba®, Hitec®, JR®, Spektrum®, Tactic™, Tower Hobbies®
http://www.towerhobbies.com/products/tx ... index.html
PostPosted: Sat 20 Oct 2012, 02:22
Nya Futaba T14SG släpps i december.
http://blogs.yahoo.co.jp/audis6ms/6935002.html
PostPosted: Sat 20 Oct 2012, 09:32
Går din att uppgradera till den modellen?
PostPosted: Sat 20 Oct 2012, 09:44
Min är redan uppgraderad till den modellen :D har 14 kanaler.
Den ska också ha telemetri men om det går att uppgradera min med mjukvaran får vi väl se.
http://www.prorc.fi/index.php?option=co ... gory_id=11
PostPosted: Fri 26 Oct 2012, 22:29
Nu släppte Futaba info om T14SG
http://futabarc.com/systems/futk9410-14sg/index.html
FASSTest tech. Flybarless gyro support. S.Bus programmability. Telemetry.
The 14SG has it all. . . and more!
PostPosted: Tue 25 Dec 2012, 16:22
Har klämt på den nya T14SG ett tag nu och läst igenom manualen och jag ger tummen upp för den nya radion.
PostPosted: Sun 06 Jan 2013, 18:58
Futaba 14SG 14-Channel 2.4GHz Computer Radio System
https://www.youtube.com/watch?v=qPIdWHuWL1w
PostPosted: Wed 09 Jan 2013, 11:13
Nya Futaba katalogen 2013 på japanska.
http://www.rc.futaba.co.jp/catalogue/data/pt_vol26.pdf
PostPosted: Sun 12 Jan 2014, 10:28
JR lanserar ny radio våren 2014
JR 28X
http://www.jramericas.com/28x/
PostPosted: Tue 14 Jan 2014, 17:55
TURNIGY X9 FUTABA MODULE ADAPTER V3
This tiny board adapts all Futaba modules to Turnigy X9 or similar JR based transmitters. You can use your OpenLRS, FrSky,etc modules. Adapter board including a Futaba male and JR female connectors and designed for perfect fit into the transmitters. You can attach it to your Tx or module with double sided foam tape for easily plug or remove from other side.
New v3 adapter boards including onboard PPM-Inverter circuit for full compatibility with all Futaba modules on the market.
http://www.flytron.com/openlrs/123-futa ... apter.html
PostPosted: Fri 18 Apr 2014, 08:51
Ny sändare från SPEKTRUM DX6 (NYHET VÅREN 2014)
https://www.youtube.com/watch?v=PznYRzESMFw
PostPosted: Thu 21 Aug 2014, 22:17
Finns ju massa andra sändare också.... Devo, Multiplex, dom där dyra jag aldrig kommer ihåg vad heter...
Måste säga att Futaba T14SG är en riktigt bra sändare.
Om min Futaba T10CP skulle gå slut idag skulle jag i panik köpa en Futaba T14SG.
MEN, finns det någon Futaba som är snäppet värre än T14SG?
PostPosted: Thu 21 Aug 2014, 22:59
Ska komma en Futaba T18SG som det har gått rykte om.
http://www.flyinggiants.com/forums/attachment.php?attachmentid=596806&d=1377715952
Users browsing this forum: No registered users and 56 guests
