It is currently Wed 18 Mar 2026, 21:05
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Yak 54 3D DLE 30cc
PostPosted: Tue 22 Mar 2011, 23:53
Lite prylar som är på väg hem till dettta projekt 8)
Capacity : 2150mAh
Constant discharge: 25C
Burst rate: 37C (15sec)
Configuration : 2S 7.4v
Pack size: 121x35x16mm
Weight : 129g
Discharge plug: XT60
Model: HD-1201MG
Voltage: 4.8~6.0v
Speed: 0.16~0.14sec
Torque: 12.2~13.2kg/cm
Weight: 60g
Aluminium ljuddämpare
DLE30 m.fl.
Avstånd monteringshål: 34mm
Avgasportens öppning: 21x11mm
Vikt: 98g
JBA IGNITION MINI TACHOMETER
Mäter varvtalet på bensinmotorn
Kopplas in via medföljande Y-kabel paralellt med hallgivaren
Varvtalsområde: 0 - 30 000 RPM
XOAR 19x8 Wooden Propeller
STRÖMBRYTARE M LADDUTTAG FUTABA
Anslutning. Futaba
Röd lampa lyser när strömbrytaren är påslagen
Utmärkt strömbrytare för t.ex. tändsystem
Dim: 46 x 14mm
G.T.POWER SWITCHAD UBEC-8A
Designed with an advanced switch mode DC-DC regulator IC.
The output current is very large, the continuous output current is up to 8A, and the burst output
current is 15A.
With the output short-circuit protection function.
A metal shield covers almost all the electronic components, and a specially made filter (ferrite
ring) is attached with the output wires to significantly reduce the electromagnetic interference.
Automatically detects the number of the lithium battery pack (2 cells or 3 cells), and shows the
battery capacity with 4 indicators (LEDs).
Shows the working status with an indicator (LED), lights when the output is in normal range.
2 Output leads to reduce the resistance when connecting the UBEC to the receiver.
Accessory: A step-down voltage regulator with 0.7V down (from 6.0V to 5.3V)
Carbon Fiber prop Spinner 77mm / 3in diameter
Carbon Fiber spinner is incredibly lightweight and has a beautiful shiny finish.The backplate is also made of carbon fiber.
Female Tamiya <-> Male XT60 (3pcs/bag)
PostPosted: Thu 24 Mar 2011, 19:28
I dag har jag installerat all elektronik! Allt linkage är på plats och injusterat! Alla utslag är färdigt injusterade. Tändbox är på plats och kopplad och klar!
Kvar att göra!
Skruva dit propellern + spinner!
Plasta kåpan och måla!
Installera tanken!
Sätta fast batteriet...! Men det gör jag till sist vid invägningen 8)
PostPosted: Fri 25 Mar 2011, 18:03
Hade allt på plats idag! så kom bakslaget!!! Måste kapa av boxen som maskin sitter fastskruvad i 4cm för att motorn kom för långt fram.
Men nu är det kapat 4 cm och förstärkt runt om boxen med nytt virke lim å skruv!
Tänkte först skita i det å flyga utan kåpa....... men nej....... så lat får man inte vara när tid finns 8)
PostPosted: Fri 25 Mar 2011, 18:48
Jäh, lite bakslag dyker alltid upp. :D
Men du har ju redan löst det.
Flygklar i vår då med Yaken ser det ut som. =)
Eller blir det premiär på isen före Djäkenfältet? ;-)
PostPosted: Fri 25 Mar 2011, 22:16
Nej det ska vara sånt där perfekt premiär på en perfekt vårdag i slutet på april eller början på maj :D
PostPosted: Sat 09 Apr 2011, 18:41
Nu har jag bytt ut hjulen till en nummer större, och tankinstallationen färdig. Spinnern är inpassad! Bara att kapa spinnerbulten nån milli på längden, sen är det ju bara att väga in flyget. Ja dom där långa fula skruvarna som kåpan sitter med ska givetvis kapas av en hel del oxå. men sen...... 8)
PostPosted: Sat 09 Apr 2011, 22:27
Har du kört motorn :?:
PostPosted: Sat 09 Apr 2011, 22:57
Nej jag tänkte försöka hålla mig tills jag kommer till fältet den här gången :roll:
PostPosted: Sun 10 Apr 2011, 15:53
I dag har jag balanserat propellern! Även navet på propellern! Genom att slipa bort lacken på olika ställen och ibland även lite av träytan! Propellern skulle vara förbalanserad.. men det va den verkligen inte 8)
PostPosted: Sun 10 Apr 2011, 16:56
Ser att du har 10" stigning på propellern.....dethär hittade på en sida för DLE 30 där man skrivit vilka propellrar man använder;
DLE - 30 PROP DATA
User Prop RPMs User Prop RPMs User Prop RPMs
Daddysam Zinger 18-8 8000 Daddysam Xoar 18-8 7800 AWD JXF 19x8 7450 gen3v8 Top Flite 18x6-10 7600 gen3v8 Winsor classic 18x8 8300 gen3v8 APC 18x8 8940 bcchi Mezlick 18x8 8500 bcchi Xoar 19x8 7400 rcign JC 20x6 7600 mpascual MenzS 18x8 8350 mpascual MenzS 19x8 7330 mpascual MenzS 20x6 7230
PostPosted: Sun 10 Apr 2011, 17:18
Inkörnings propp blir som rekommenderat 18x8
PostPosted: Mon 18 Apr 2011, 20:23
Nu har jag mineral olja till inkörningen 8) Och akrylat bensin 2% efter!
PostPosted: Tue 19 Apr 2011, 08:48
Ser ingen kill switch i flyget?
PostPosted: Tue 19 Apr 2011, 10:15
Stämmer! skulle beställa dspi men den va slut då! Så de blidde ingen :!:
PostPosted: Tue 19 Apr 2011, 19:06
Själv köpte jag en 42% ELECTRONIC IGNITION KILL SWITCH av aircpro till min Sundowner
PostPosted: Sun 05 Feb 2012, 01:05
Var flyget utom all räddning eller hur blev det efter senaste landningen.
PostPosted: Sun 05 Feb 2012, 12:05
Allt utom flyget helt 8)
PostPosted: Sun 14 Aug 2016, 10:07
Vart tog motorn vägen?
PostPosted: Sun 14 Aug 2016, 17:20
Först till Atte och så hamnade den i min Cave där alla andra DLE 30cc finns
PostPosted: Sun 14 Aug 2016, 20:10
Så det finns 3 st på holmen och de är hos dig? Förutom en i Oscars Yak 55. :-D
