Post subject: AAI RQ-7 Shadow FPV 2000mm Laser Cut Kit
Posted: Fri 06 May 2016, 09:54
Joined: Fri 12 Nov 2004, 15:27 Posts: 16694 Location: Solkusten
Börjar dyka upp FPV-flyg med långa flygtider så sätt i ett 10000mAh 4S och du kan vara uppe länge. Passligt flyg att bygga som kit nästa vinter having a range of over 100km and a 4 hour on-target loiter time.
In real life, the AAI RQ-7 Shadow is a battlefield UAV used by the armed forces of Australia, Italy, Sweden, the United States and others to provide a reconnaissance, surveillance and as a target acquisition platform.
Over 500 RQ-7 Shadows are in operational use throughout the world carrying electro-optic/infrared imaging sensors and having a range of over 100km and a 4 hour on-target loiter time. The specifications also required the UAV to be able to land in a sports field. Our RQ-7 Shadow can't offer a 4 hour duration or a 100km range, but it is certainly a fantastic FPV platform with all of the highly practical features of the full size, including the aerodynamically proven inverted V tail, twin boom layout, center mounted pusher motor, fixed tricycle undercarriage and the huge central nacelle giving a clear view for your cameras and sensors. For the scale enthusiasts among us the kit builds into quite an accurate representation of the full size Shadow and, at 2000mm wingspan the large scale enthusiasts won't be dissappointed either as this one is very nearly 1/2 scale! The kit features a full set of components, laser cut from highest quality balsa and ply to make construction as fast, accurate and enjoyable as possible. A full accessory pack, leaving you with adhesives and covering material to provide in order to finish the model. Features: • Highly capable FPV platform • Accurate laser cut parts • Quality balsa and plywood construction • Full accessory pack • Easy to follow manual • Large payload capacity • Landing gear included Specs: Wingspan: 2000mm Length: 1630mm Flying weight: 3200~4000g Radio: 4 channel minimum Motor: 2820 900-1100KV brushless outrunner ESC: 60A Propeller: 12 x 6 Required: 4 Channel RC gear (minimum) 2 x 17g servos 2 x standard servos 5000-10000mAh 4S LiPoly battery 2820 900-1100KV brushless motor 60A ESC w/BEC Covering Adhesives Choice of FPV equipment (optional) http://www.hobbyking.com/hobbyking/stor ... t_Kit.html
Joined: Sun 16 May 2004, 01:07 Posts: 31955 Location: Mariehamn
Woah! Den där har jag vart sugen på tidigare. =) MEN... då var det "originalet" (läs: också kopia på riktiga RQ-7'an, men ARF) som är 2,6 m om jag minns rätt (fanns en på 4,5 eller nåt också om man vill vara värre)... det där är ju en HobbyKing äuhm...
2000 mm är inte såå stort trots allt. Vet inte hur den ska kunna flyga så länge när andra knappt klarar 2h i den storleken och då är de gjorda i EPO.
Läste texten lite noggrannare... "Our RQ-7 Shadow can't offer a 4 hour duration or a 100km range, but it is certainly a fantastic FPV platform" Haha... jaså det var originalet som tex militären använder som kan flyga 4 timmar.
Skulle vara skoj bygga en större än Majan (som är 2200 mm), men vad ska man ha den till? Visserligen skoj att testa en massa med. Kanske ännu bättre övervaknings/spaningsflyg?!
Men om man ska skaffa nåt nytt utöver Maja som är större... så får man börja fundera på arbeta tillsammans med nån.
Den verkar vara väldigt lättbyggd. De kallar den FPV-kärra, men den har inget byggt för det?! Flyger den bra då? Skulle nog va kul bygga. Hade jag inte haft så förbannat med flyg redan så... Och vad skulle man ha den till? Inte FPV, det finns så mycket annat som är bättre för det ändamålet. Men kanske nåt att sätta denna i: https://www.youtube.com/watch?v=4RDh9GOsXeE
Börjar va jobbigt nu. Måste ju få Skua klar för bövelen. Får ju såna habegär, den där 2,6 meters Mini Mugin sku duga bra Undrar hur mycket skoj man sku kunna klämma in i den..... Går säkert ett par tusingar om man riktigt vill
_________________ MC or RC... It´s just a 2 letter hobby....
Joo, det är riktigt skoj bygga såna här flyg med massa kejkor. Mini Mugin är väl till och med bensindriven, helt annan nivå. =) Frågan är vad man ska göra med flyget...
Skick de till kökar å ta en bild på kyrkan å hem igen via Grisslehamn?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
