Turnigy Accucel-8 150W 7A Balancer/Charger
30€Attachment:
The Accucel-8150 is a Lipoly/LiFe battery charging workhorse.
Capable of handling up to 8S, 7A or a maximum of 150W charging current plus it balances and discharges packs which is critical for keeping your expensive batteries in perfect condition.
This charger has a 12v input and can be used with a mains 12v power supply or your car battery when at the field.
TURNIGY Accucel chargers are built with quality components and produced in robotic pick-n-place SMT technology machines to produce a reliable and accurate charger.
Spec.
Operating voltage range: 11.0~18.0Volt
Circuit power: max. 150W
Charge current range: 0.1~7.0A
Discharge current range: 0.1~5.0A
NiCd/NiMH battery cell count: 1~27 cells
Lithium bettery cell count: 1~8 Series
Pb battery voltage: 2 to 36V
Weight: 625g
Dimensions: 170X125X35mm
12V Note: Power supply not included.
