It is currently Fri 27 Mar 2026, 19:27
Post new topic Reply to topic  [ 205 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
PostPosted: Mon 03 Nov 2008, 15:40
Film på en ovanlig och dyr O.S OS IL300 (rak 4). Notera det mycket speciella ljudet 8)
Kanske nån är sugen på att köpa en sån http://www.modellhobby.com/product_info ... ts_id=4979
Film: http://www.youtube.com/watch?v=0BcUvz_x ... re=related
 Post subject: Ny motor från O.S
PostPosted: Tue 04 Nov 2008, 20:45
Ny motor från O.S......!
OS FSα-110 Engine with F-5040 Silencer
OS FSα-110 Engine is the third in the FSα series following the FSα-56 and FSα-81 sharing the same basic design concept offering more power for the 91 size 4-stroke models, a more pleasant exhaust sound and user friendly features. The same mounting bolt pattern as the FS-91SII for easy replacement (carburetor and silencer positions are different)
A newly designed silencer with the exhaust outlet direction and distance between exhaust port and silencer adjustable. A new “Blow-by” internal oil system eliminates the need for a crankcase breather nipple. A broad power band suitable for scale models as well as sport models. A new 60Y carburetor with extended intake tube to eliminate reserve flow tendency of air/fuel mixture.
Displacement(cc): 18.0cc(1.10 cu.in.)
Output(ps): 1.8ps(10,000r.p.m.)
Output(rpm): 2,000-11,000r.p.m.
Weight(g): 600g(19.2 oz.)
Kan beställas hem här: http://shop.singahobby.com/ http://www.mamut.net/hab_ab/shop/
 Post subject: Ny motor från Saito (Bensin)
PostPosted: Sun 09 Nov 2008, 14:13
20,52cc. 1800-9500rpm. vikt 675 gram. Propeller 14x8, 16x6.
http://www.sodersrchobby.se/sodersrchob ... pid=SAFG20
PostPosted: Sun 09 Nov 2008, 16:38
Itervju med kille insatt i Saitomotorer om nya SAFG20
http://www.youtube.com/watch?v=EYB4ltcGguc
PostPosted: Wed 19 Nov 2008, 10:47
Det här kallar jag motor :)
http://www.youtube.com/watch?v=Y1rjRmTV ... hp?t=22056
PostPosted: Wed 19 Nov 2008, 13:01
JS_ wrote:
Den går ej att köpa i butik....! Tillverkad av nån motorguru hemma i hans garage! Men imponerande är det i alla fall 8)
PostPosted: Sun 07 Dec 2008, 13:58
Vem av oss ska testa denna smarta lösning.....ombordgenerator till modellflyg :D
Köp här http://www.hobbypeople.com/shop/index.p ... ts_id=6599
Köp här http://www3.towerhobbies.com/cgi-bin/wt ... LXFV20&P=7
To download Installation Instructions in pdf http://www.sullivanproducts.com/S660INST.pdf
Generator för större motorer finns http://www.sullivanproducts.com/GenesysMainFrame.htm
PostPosted: Tue 06 Jan 2009, 00:16
Kanske man borde byta topp på en 2-taktare och köra med två glödstift.
PostPosted: Thu 15 Jan 2009, 00:25
http://www.aircpro.com/airc/homepage.ns ... rtID=7302-
<<<<<<<JBA 2-TAKTSMOTORER PÅ INGÅENDE
Nu lägger vi JBA motorer till vårt sortiment av kvalitetsprodukter.
Jiangnan Blue Arrow har varit ett aktat namn för tillverkning av RC motorer i hela Europa och Asien under många år. JBA designar och tillverkar motorer för flygplan, helikoptrar och bilar och har tillverkat motorer för andra märken i många år. Numera är motorerna även försedda med namnet JBA. Tillverkningen sker i den egna ISO9001 certifierade produktionsanläggningen med CNC-bearbetning, omfattande kvalitetskontroller och en ständigt pågående forskning, JBA producerar årligen mer än 200.000 motorer för RC hobbyn.Från konstruktion till produktion har JBA har satt in alla tänkbara resurser för att producera högsta kvalitet på motorerna, men till ett överkomligt pris. JBA motorerna finns i 2- takts utförande och storlekar från .39 (6.34cc) till 1,40 (22.5cc). Motorerna levereras komplett med JBA glödstift samt JBA:s effektökande Power Box ljuddämpare och är startade och testkörda på fabriken så att dom nästan genast börjar leverera kraft och effekt, som finns så det räcker. Den låga vikten tillsammans med effekten i JBA motorerna, gör att dom hävdar sej utomordentligt väl i konkurrensen med andra märken i samma storlek och klass.
PostPosted: Thu 15 Jan 2009, 00:33
J
Vet du vad motorerna väger?
PostPosted: Thu 15 Jan 2009, 00:38
Ännu en till SC, SK, ASP, SY, ... :roll:
PostPosted: Thu 15 Jan 2009, 00:41
J
Vikten hittar du här http://www.throttlestore.com/engines/gl ... px?lang=EN
och ja ännu en till SC, SK, ASP, SY, ... m.m
PostPosted: Thu 15 Jan 2009, 00:46
Och med det menar jag att det blir billigare köpa en riktig motor
och köra in en tank och flyga, än att köpa en Kina-motor och bli
arg och fippla och köra in tank efter tank (kostar bränsle) och
sen efter några kvällars körning, så går den dåligt, för att man
inte orkade köra in den bra. En OS-motor håller ju otroligt länge
om man sköter den som man sköter motorer. =)
PostPosted: Fri 16 Jan 2009, 18:49
Måste med ge,från att vara motståndare efter att provat 4 takt
tidigare som ej gick bra,så har jag ändrat mig efter dagens körning
inget vrål lugnt o fint kraft fanns men det skall nog vara ombord glöd.
PostPosted: Fri 13 Mar 2009, 17:28
DL har nu kommit ut med två nya bensinare.
DLE-55 SINGLE CYLINDER NYHET
DLE-111 TWIN CYLINDER NYHET
PostPosted: Wed 08 Apr 2009, 22:34
1 % oljeinblandning räcker om du kör på detta..svensk produkt..biologiskt nedbrytbar..luktfri..rökfri... 8)
http://www.stenmarksmaskin.se/default.aspx
En revolution inom 2-takts smörjning. Produkten innehåller Bor (B) som är ett halvmetalliskt atomslag. Bor har en av de lägsta friktions koefficienter som finns.
Användningsområden är alla 2-taktsmotorer med separat oljeinjektion t.ex i snöskotrar, båtar, go-cart, mopeder, motorsågar, motorcyklar, röjsågar m.m.
-Lukt och rökfri
-Högre effekt
-Mindre slitage
-Bättre förbränning
-Bränslebesparande
-Biologiskt nedbrytbar
-Låg friktion
-Svenskt patent
Pris: 199,00 kr
PostPosted: Sun 28 Jun 2009, 16:51
Hetaste nytt om nya motorn från DLE
DLE-30
Vikt bara 910g med en totalvikt på 1100g
Mitten av Juli ska den börja säljas.
http://www.5irc.com/content.asp?id=1730306&db=TECH
http://6.cn/watch/11329626.html
PostPosted: Wed 09 Sep 2009, 09:45
DLE-30 finns nu att köpa på http://www.aircpro.com/
Såg att Östersund har börjat sälja DLE också.
PostPosted: Fri 02 Oct 2009, 23:39
Nu går det också att köpa nya DLE-30 från Hobbycity för $269.95
http://www.hobbycity.com/hobbycity/stor ... HP@8500RPM
PostPosted: Tue 06 Oct 2009, 15:31
OS nya bensinmotor GT55
http://www.os-engines.co.jp/091003/index.htm
