It is currently Mon 27 Apr 2026, 12:01
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3  Next
 Post subject: ZOHD Talon GT Rebel
PostPosted: Mon 25 Mar 2019, 21:41
ZOHD Talon GT Rebel
Promotion Sale From March 17 to April 1.
Processing time:Expected on March 31, 2019
One of the most capable FPV planes in 2019
Can compete in range and speed with planes twice as big and twice the cost without blinking.
A true king of the skies … join us in this incredible adventure!
Flying speed: 30-100+km/h
Pre-order en ZOHD Talon GT Rebel så startar denna tråd.
Expected Shipping Date: 2019-03-31 är det på den.
Banggood
https://www.banggood.com/ZOHD-Talon-GT- ... rehouse=CN
 Post subject: Re: ZOHD Talon GT Rebel
PostPosted: Mon 25 Mar 2019, 21:48
Forum: RCGroups
https://www.rcgroups.com/forums/showthr ... ebel%C2%94
Facebook
ZOHD Talon GT Rebel owners group
https://www.facebook.com/groups/1040987086086467/
ZOHD Dart, Dart XL, Nano Talon and Orbit Owners Group
https://www.facebook.com/groups/ZOHDOwners/
PostPosted: Mon 25 Mar 2019, 21:51
ZOHD Talon GT "Rebel" - OFFICIAL INTRO VIDEO
PostPosted: Tue 26 Mar 2019, 10:34
PostPosted: Tue 26 Mar 2019, 19:12
Material: Biodegradable BEPP
Wingspan: 1000mm(39.37'')
Length: 660mm(25.98'')
Motor: 2216-1300KV
ESC: 40A w/5V 3A BEC
Servos: 9g Metal Gear
Prop: 8x5
Wing area: 14dm2
Wing load: 92.8g/dm2(Max.)
Recommended Battery: 4S 3300-4400mAh
http://myosuploads3.banggood.com/produc ... cument.pdf
https://drive.google.com/file/d/1YStaIO ... 0i2Lb/view
PostPosted: Tue 26 Mar 2019, 20:24
Description:
Away from our initial debut in the RC world, ZOHD has evolved into a mature, committed and responsible company.
The Talon GT “Rebel” is the continuation of our new series called MKII, started with the highly acclaimed Dart XL “Extreme”. This series will feature an incredible set of high quality and ORIGINAL innovations, intended to give you the FPV aircraft for casual, mid and long range.
With MKII, without cutting any corners, we went straight ahead with 100% biodegradable and environmentally friendly materials, metal gear servos, high quality power plants, protection for leading edges and skids, wing fences, vortex generators, dedicated bays for FPV gear, revolutionary multi-cam hard noses and much, much more.
Talon GT is one of the most capable FPV planes in 2019, regardless wingspan and price. Can compete in range and speed with planes twice as big and twice the cost without blinking. Specifically design to fly with modern flight controllers, high power video transmitters and long range systems, Talon GT will give you the best FPV experience to date. Easy assembly, setup and maintenance… A true king of the skies!
This is it! ZOHD Talon GT “Rebel” is ready to hit the skies around the world, and this is just the beginning… join us in this incredible adventure!
Features:
- Thanks to its revolutionary and careful design, the plane performs and looks like no other in the market.
- Small size airframe optimized for long range and portability, marrying the best from the old school with cutting-edge production technologies.
- Carefully chosen airfoil gives the aircraft an incredible lift power and excellent handling in any circumstances.
- Detachable wing and tail make it portable for an easy transport and deploy.
- Keeping the tradition: Familiar V tail layout, easy to set up.
- Fly Green: New ZOHD’s exclusive BEPP material isn’t only crash resistance, but even more important: 100% biodegradable. Future generations will thank you for that.
- Light-weight composite hard nose for better protection of your expensive camera gear
- Multi-camera nose: Compatible with 99% of the FPV and HD cameras in the market: Runcam HD, 2, 3S, Swift, Eagle, Split, GoPro H4-5-6-7, Session and much more!
- Reversed wingtips, provide more lift force and ensure a super efficient wing surface
- Carefully engineered wing fences.
- Reinforced pushrods for better overall performance and safety.
- Load it as much you want with a huge equipment bay!
- Computer designed optimized air flow po d, that maximizes cooling, reducing the risk of crashes for overheated electronics. No more DIY foam cutting!
- Impact resistant protection cover for main wings leading edge and belly will keep your plane away from wear and tear.
- Built-in carbon fiber tube inside main wings for enhanced performance and rigidity.
- Built-in carbon fiber square rod reinforcement all along the fuselage.
- Exclusive VTX / RX bays with excellent air flow and away from interferences.
- U-stand for comfort and convenience while setting up the plane. Ideal to level any kind of flight controller in the workbench.
- Full spare parts supply available, worry free fun.
Package Included:
1x ZOHD Talon GT Rebel 1000mm Wingspan V-Tail BEPP FPV Aircraft PNP
PostPosted: Wed 27 Mar 2019, 21:54
PostPosted: Thu 28 Mar 2019, 23:58
Saker som ligger och väntar på flyget.
Telemetri - Mottagare - Futaba R7008SB 2.4GHz FASSTest.
Autopilot 6-axligt Gyro m.GPS (flyg hem funktion)
PostPosted: Fri 29 Mar 2019, 14:27
Inte längre Pre-order på den utan in stock. Processing time: Ships in 24 hours.
Min står nu som Shipped Mar/28/2019 20:56:27
Fortfarande som 41% Off Promotion Sale From March 17 to April 1.
Bara att välja flyg eller tåg.
European Railway Direct Mail Free shipping 40-50 business days Tracked
Air Parcel Register 3,57€ 7-25 business days Tracked
EMS Express Mail Service 13,54€ 7-15 business days Tracked
EU Priority Line 22,67€ 7-15 business days Tracked
Expedited Shipping Service 29,45€ 5-8 business days Tracked
PostPosted: Sat 30 Mar 2019, 20:26
PostPosted: Sat 30 Mar 2019, 20:48
Jaså den har V-tail den där... ;-)
PostPosted: Sat 30 Mar 2019, 20:52
Jo det snackades mycket om V-tail på fältet i dag :D
PostPosted: Sat 30 Mar 2019, 21:20
Det var X-UAV Clouds jag tänkte på som också har V-tail och väldigt populär V-tail-flyg.
PostPosted: Sun 31 Mar 2019, 11:23
Lite olika åsikter ute på nätet om ZOHD Talon GT Rebel.
Vissa dömer ut den helt och hållet medan andra gillar den skarpt.
Flyget har knappt kommit ut på marknaden bara några få har fluget det.
Tydligen inte ett flyg för alla utan den ska vara lite mera utmanande att flyga.
Ett flyg som det är fart på och som man inte tröttnar på så fort.
PostPosted: Sun 31 Mar 2019, 11:54
Vad är det folk inte gillar med det?
PostPosted: Sun 31 Mar 2019, 12:07
ZOHD Talon GT Rebel / No Hands On Review / Why People Are Upset
Se också denna review
Pass the Tea Vicar" - ZOHD Talon GT Pre-Release Review
https://www.youtube.com/watch?v=TG4nVF4pG0A
PostPosted: Sun 31 Mar 2019, 13:09
Nå, jag trodde du visste vad folk inte gillade. =)
PostPosted: Mon 01 Apr 2019, 20:58
Ska prova en AKK X-2 till flyget som sändare.
Features
Support Smart audio
25mW/200mW/600mW/1200mW power switchable
One button frequency and power setup
OSD configuration using smart audio
7-26V input with 5V output for camera
With MIC
Specification
Input Voltage : 7V-26V
Extra Features : Smart audio/1000mW for long range
Power Supply : 5V Camera @ under 500mA max.
Output Power : 25mW/200mW/600mW/1200mW
Antenna Connector : MMCX
Cable Connector : JST 6P
Dimension : 22 x 32mm
Weight : 6.8g(excluding antenna)
AKK X2-ultimate International 25mW/200mW/600mW/1200mW 5.8GHz 37CH FPV Transmitter
PostPosted: Mon 01 Apr 2019, 21:58
PostPosted: Mon 01 Apr 2019, 22:17
AKK is bringing forth new items all the time
AKK it is truly one of the best on the 5.8mhz market right now and AKK is well known for the quick speed of new arrivals.
https://www.rcgroups.com/forums/showthr ... ime/page83
