It is currently Wed 01 Apr 2026, 07:14
 Post subject: New Beetle Turbo
PostPosted: Wed 09 Sep 2009, 20:21
Lite vw porr. Man blir helt svag att se på den :)
2.9 Pauter Turbo
http://www.youtube.com/watch?v=hF2A7c_1pDo
PostPosted: Wed 09 Sep 2009, 20:41
Kör: VW
här e hur botten e byggd o priser, bara o beställa efter :)
Parts list for Pauter Super Pro long block kit
1 90-1000-F/C Pauter Big Block for Chrysler or Ford main bearing saddles 2700.00
includes: wet or dry sum pan, top & front covers, flywheel plate, distributor clamp & misc fasteners
1 63-394 82mm to 94mm Pauter billet crank / flanged end 2975.00
1 set 30-063 Big Block cam gear et 298.50
1 set 50-660 4340 Chrome moly billet rods, V8 style 860.00
1 kit 86-030 Roller cam and lifters - grind to be determined 972.00
1 kit 40-619 Bore kit, includes pistons, cyls, rings, pins & gaskets (conventional only, modular at additional cost) 1380.00
1 pair 90-200TM Pauter Super Pro heads, titanium valves & retainers, Vasco Jet springs, 3600.00
valve covers, intake manifolds, ported & polished, bored & cc'd
1 set 90-300 Exhaust flanges for customer header system 45.00
1 set 90-301 copper exhaust gaskets 35.00
1 set 90-1012 Chrome moly head stud kit w/nuts & washers 375.00
1 set 81-2?0 1.4, 1.5 or 1.6 Super Pro billet roller rocker kit 539.00
1 set 80-099 Super Pro pushrod tubes 145.00
1 set 80-070 3/8 or 7/16" double-tapered HT chrome moly pushrods, to length 375.00
1 kit *BRN Rod/main/cam bearings, all seals 315.00
1 40-412 Copper head gaskets for bore kit (head to cyl interface) 80.00
1 30-XXX Flanged-end flywheel (specify clutch mods) 475.00
1 94-400 4-stage Center-Flo oil pump, VW drive, no fuel pump drive 895.00
(does NOT include fittings or braided oil lines)
1 94-405 3-into-1 manifold for oil pump 67.50
QUOTATION TOTAL $ 16,1332.00
