| Bygg din egen cub http://forum.motorportalen.net/viewtopic.php?f=45&t=12812 |
Page 1 of 1 |
| Author: | Kamikaze [ Wed 04 Feb 2015, 23:20 ] |
| Post subject: | Bygg din egen cub |
http://www.cubcrafters.com/carboncubex ![]() Simply the best Cub kit available. Nearly 300 pounds lighter and much stronger than an equivalent Super Cub. Half the parts of a Super Cub means half the build time. Ready to cover in as few as 200 hours. Compatible with engines up to 180 horsepower (!) while still qualifying as a Light Sport.* Fuselage is four inches wider and the door is 50% larger for significantly increased comfort. Absolutely complete airframe kit, including every necessary nut, bolt and washer. Includes covering materials. An excellent choice for the first-time builder. *The builder is legal to fly the Carbon Cub EX as a "Light Sport" pilot as long as the kit is certified at a maximum weight of 1,320 lbs. Our kit was tested to ASTM standards at a gross weight of 1,865 lbs. If you decide to set the gross weight at 1,865 lbs, you will not be allowed to fly as a "Light Sport" pilot; and you will need a medical and a private pilots license. |
| Author: | MickeM [ Wed 04 Feb 2015, 23:24 ] |
| Post subject: | Re: Bygg din egen cub |
Jag bygger gärna ett flyg till, det var ett av det roligaste jag gjort. Kul projekt. Ser ut att vara mer lättbyggd än Skyrran. Köper du? |
| Author: | Kamikaze [ Wed 04 Feb 2015, 23:58 ] |
Ha ha...nej |
