It is currently Fri 26 Apr 2024, 19:04
 Post subject: Säljes - Flight Control Board Skyline32 Mini
PostPosted: Sat 02 Jul 2016, 00:09
Säljes
1st Skyline32 Mini flight controller with its Cleanflight and Baseflight (NAZE32 firmware) support. 15€
 Post subject: Re: Säljes - Flight Control Board
PostPosted: Sat 02 Jul 2016, 09:18
Den där Skyline... vad ingår och stöder den Elevons så jag kan ha den på min Caipirinha?
Har du nån info-sida?
PostPosted: Sat 02 Jul 2016, 09:55
Skyline32 Mini flight controller ny i obruten förpackning.
Manual - http://www.hobbyking.com/hobbyking/stor ... 800X35.pdf
32-bit ARM micro processor running at 3.3V / 72MHZ.
With gyro, compass, extended reservation position for accelerometer, barometer.
Manual mode, Angle mode, Horizon mode, heading hold mode, head-free mode, Altitude hold mode (this mode is available in advanced version)
Support Quad-,Tri-,Hex- ,various multirotors.
Flexible RC input: standard, CPPM (PPM SUM)
Micro-USB: Flashing firmware & adjusting parameter
Parameters adjustment interface: Baseflight-Configuration.
GPS position hold / “Go home” function(GPS Optional).
 Post subject: Re: Säljes - Flight Control Board Skyline32 Mini
PostPosted: Sat 02 Jul 2016, 11:16
Ok, den stöder endast multicoptrar.
