It is currently Fri 27 Mar 2026, 14:47
Post new topic Reply to topic  [ 205 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
PostPosted: Wed 25 Apr 2007, 10:02
Snart kan du docktorera inom detta ämne Micke :lol:
PostPosted: Tue 19 Jun 2007, 23:48
Lite info om hur man meckar på metanolmaskiner http://www.smbf.info/Hydro/byggsidan/motor_pipa.htm 8)
PostPosted: Tue 19 Jun 2007, 23:53
SMBF är en skitbra sida. De pysslar med båtar och racing. De nissarna
är duktiga på motorer. Min Tonka hittade jag via SMBF. =)
Hydro är en galen båttyp som ser ut som tre pontoner och en för
stor motor som ylar på som tusan och båten går sjukt snabbt.
PostPosted: Wed 18 Jul 2007, 11:16
Eftersom Mr X har en unik motor på Gång, Så måst jag ju visa hur den fungerar och ser ut 8)
The RCV 4-cycle engine has only one more moving component than a 2-cycle engine -the rotating cylinder itself. The cylinder is suspended between two bearings which allow it to rotate freely around the piston; the piston, and crank are entirely conventional. A gear formed around the base of the cylinder meshes with a gear on the crank. As the piston reciprocates and the crank turns, the cylinder rotates around the piston.
At the top end of the rotating cylinder there is a single port leading to the combustion chamber. This is surrounded by a fixed timing ring with three radially arranged ports; inlet, ignition and exhaust. This simple valve arrangement serves the combustion chamber as the engine cycles through the conventional 4-cycles: induction, compression, power and exhaust. Ignition is achieved through a standard 4-cycle glow plug exposed once only during each complete cycle.
The rotating cylinder is effectively combined with the rotary valve in a single component hence - RCV - Rotating Cylinder Valve.
Image Sprängskiss på en RCV SP
Image Sprängskiss på en RCV CD (MrX Nya Maskin)
PostPosted: Wed 18 Jul 2007, 13:16
Den där maskinen ska bli intressant att se i verkligheten!
PostPosted: Wed 18 Jul 2007, 13:54
Sjuuk motor! :D Haha! Lite wankel över det hela?
PostPosted: Wed 18 Jul 2007, 17:03
Så här låter motorn
http://www.rcgroups.com/forums/showatt. ... id=1000714
Pluses:
* Shorter physical size
* Excellent fit and finish to all parts
* Great 4-stroke sound
* Easy to setup and adjust
* Fuel economy
* Less parts = less maintenance (no valve train)
* Excellent performance - great torque
* Great customer support
* Two year warranty
 Post subject: 9-cyl stjärnmotor!
PostPosted: Wed 15 Aug 2007, 17:05
9-cyl stjärnmotor som är en rc-maskin http://www.youtube.com/watch?v=Y1rjRmTV ... ed&search= 8)
 Post subject: Cold start 1000 hp radial engine
PostPosted: Wed 15 Aug 2007, 17:07
The real stuff http://www.youtube.com/watch?v=Z2ChXmMi ... ed&search= 8)
 Post subject: Wankel
PostPosted: Fri 17 Aug 2007, 16:17
O.S har en trevlig liten vankelmotor....8)
http://www.youtube.com/watch?v=zb_J-XrT ... ed&search=
http://www.youtube.com/watch?v=eTbg92mR ... ed&search=
http://www.youtube.com/watch?v=Z-MY-Lwm ... ed&search=
Finns att köpa här t.e.x http://www.modellhobby.com/product_info ... ts_id=3835
PostPosted: Fri 17 Aug 2007, 18:16
Wankel?! :D Ja men jäklar va skön! Haha... Degerth och savv3... har ni
sett? Köpt bort och skaff flyg ni med =) Amper motor.
PostPosted: Wed 22 Aug 2007, 20:34
Kör ej era 4-Taktare på bränslet vi alla har kört på! Började misstänka att nått skumt va i görningen när även min 4-Taktare började bete sig som Bernts A.S.P motor! d.v.s stanna så fort den blir varm! Och tappa orken! Läste i dag att min maskin skulle ha 30% oljeblandning! Soppan vi kör på har ju bara 14% :shock: Inte undra på att maskin går tungt och blir het och röker nästan ingenting på fullgas! Inte undra på att Bernts 2-Taktare började spruta aluminium ur sig! Vi ska nog alla börja blanda i mera olja i vårat bränsle! Särskillt dom som kör 4-Takt....... 8) Så JS! Du får ta hem en dunk syntet-olja åt mig när du åker till sweden! Om du har möjlighet 8)
PostPosted: Wed 22 Aug 2007, 21:30
Det skall väl gå bra
PostPosted: Wed 22 Aug 2007, 21:58
Kom på att du inte behöver köpa olja Jocke! Ska flyga 2-takt nu ett tag framöver!
PostPosted: Wed 22 Aug 2007, 22:23
ok
PostPosted: Sat 25 Aug 2007, 12:40
Kan man svänga en 2 taktare uppsom ner :?:
Fast det va väl nåt med att förgasarn skulle va i linje med tanken va :?:
 Post subject: Moki motor
PostPosted: Sat 25 Aug 2007, 13:53
http://www.myvideo.de/watch/1221357 Lyssna och njut av Moki stjärnan! Skruva upp volymen
PostPosted: Sat 25 Aug 2007, 13:54
Om du har blandningsnålen i center på tanken! Inte under helst! För då rinner soppan ut automatiskt genom förgasaren! Jag vet! Har testat redan 8)
PostPosted: Sat 25 Aug 2007, 13:57
Ett härligt skalaflyg med underbart skalaljud http://www.myvideo.de/watch/402790 8)
PostPosted: Sat 25 Aug 2007, 14:04
Stort 3D flyg med bensinare som spelar fan... http://www.myvideo.de/watch/1416673 8)
