RC-Skvaller 2015 http://forum.motorportalen.net/viewtopic.php?f=15&t=12771 |
Page 11 of 12 |
Author: | JS_ [ Tue 01 Sep 2015, 20:28 ] |
Post subject: | Re: RC-Skvaller 2015 |
MickeM wrote: MickeM wrote: Mr X wrote: Undrar vem som köpte Super Decathlonen, Bernt kan det inte vara för han skulle ha skyllt köpet på mig WTH! Är den såld? Udda modell med färre fönster, hittade aldrig tillverkare på den. Tomt med info om detta... =) JS? Den är jag oskyldig till |
Author: | Kamikaze [ Wed 02 Sep 2015, 15:45 ] |
Nu är Bernts stora Cranfield startad och injusterad! Färdig att ta upp i luften! Motorn gick vackert, Lättstartad liten rackare med stadig tomgång |
Author: | Bernt [ Wed 02 Sep 2015, 18:01 ] |
Undrar om jag skall få upp o ned denna pjäs, verkar nog vara litet stor för jäkenfältet. |
Author: | Kamikaze [ Fri 04 Sep 2015, 13:29 ] |
8/08/2015 9:53:12 PM Beställt! Order Messages; Notes; PHCS_Hazel - 14/08/2015 16:01 : "Delayed Order Checking with Order Processing Officer via chat" PHCS_Dennis - 1/09/2015 13:25 : Canceled BK item 1*WHS3MM-BLUE and restored 1.08 BP No shipping difference Checking with Order Processing Officer Follow up for this delay order has been made via chat PHCS_Aumer - 3/09/2015 17:10 : Delayed Order Checking with Order Processing Officer via chat PHCS_Jordan - 4/09/2015 10:16 : WHS-2MM-RED - no stock 9/1 PHCS_Aumer - 4/09/2015 19:19 : CANCELLED ITEM/S 1*WHS-2MM-RED = $0.81 No Shipping Difference Stored Bonus Points = $0.81 via chat |
Author: | Kamikaze [ Fri 04 Sep 2015, 21:26 ] |
Kamikaze wrote: :lol: 8/08/2015 9:53:12 PM Beställt! Order Messages; Notes; PHCS_Hazel - 14/08/2015 16:01 : "Delayed Order Checking with Order Processing Officer via chat" PHCS_Dennis - 1/09/2015 13:25 : Canceled BK item 1*WHS3MM-BLUE and restored 1.08 BP No shipping difference Checking with Order Processing Officer Follow up for this delay order has been made via chat PHCS_Aumer - 3/09/2015 17:10 : Delayed Order Checking with Order Processing Officer via chat PHCS_Jordan - 4/09/2015 10:16 : WHS-2MM-RED - no stock 9/1 PHCS_Aumer - 4/09/2015 19:19 : CANCELLED ITEM/S 1*WHS-2MM-RED = $0.81 No Shipping Difference Stored Bonus Points = $0.81 via chat Fick i nerverna och nollade skiten i kväll! Fick allt som bonuspoäng |
Author: | Kamikaze [ Fri 04 Sep 2015, 21:44 ] |
Beställde 2 billiga laddare som tydligen kan ladda Lihv bolt. The Turnigy Accucel 6 Balance Charger utilises quality FET's and resistors to accurately balance and charge LiPoly, LiFe, LiHV, NiMH, Nicd and Lead Acid batteries. If you are looking for a charger for your Bolt batteries this unit is perfect as a low cost, go anywhere solution. The Accucel-6 will handle LiHV/LiPoly/LiFe up to 6S and NiMH/NiCd up to 15S and shows individual cell voltage throughout the charge cycle. The intuitive menu system means charging and cycling is an easy process and can be done quickly and accurately. And because this is a 12v DC charger you can power it up at the field using a 12v car battery or at home with a 12v power supply. It is also able to connect this charger to your PC using a USB cable (not supplied) so you can monitor pack voltage, cell voltage and other data through real-time graphs during charging. You can also control charging and update firmware from "Charge Master". Also included with the Accucel-6 are input and output wires with XT60 plugs. ATTENTION. There are several chargers now entering the China market that look similar to the Accucel. These chargers are produced with cheaper FET's and are unfortunately much less accurate and very unsafe. There has been reports of the copied chargers over-charging packs and not balancing correctly. The Accucel-6 is the first charger in the market with this PCB layout Circuit design. Any charger with the same circuit diagram is most definitely a copy. We have tested the copied chargers ourselves, their componentry is of a very low quality and the manufacturing company that has produced the copy has used a process of duplicating our CPU(MCU)'s hex file and flashed a similar chip(MCU) to produce a similar product. This means they do not have the original code and therefore cannot bug-test(QC) or update the charger at any point. Our chargers have CE and RoHS certification, proving their safety. Plus, thousands of customers the world over have used our chargers with excellent results. Your batteries are expensive. We understand this and thats why we will not carry low-quality charging devices. Trust only in TURNIGY® quality charging devices. Features: • Microprocessor controlled • Individual cell balancing • LiHV, Li-ion, LiPoly and LiFe capable • Ni-Cd and NiMH capable • Delta-peak sensitivity (NiMH/NiCd) • Lead Acid capable • Large range of charge currents • Terminal Voltage Control (TVC) • Lipo Battery Meter • Battery Internal Resistance Meter • Store function, allows safe storage current • Time limit function • Temerature Cut-off (20-80 degree Celcius/68-176 Fahrenheit) • Input voltage monitoring. (Protects car batteries at the field) • Data storage (Store up to 10 packs in memory) • Battery break in and cycling. (1-5 cycles) Specs: Input Voltage: 11~18v Circuit Power: Max Charge: 80W / Max Discharge: 10W Charge Current Range: .1~10.0A Balance Cells: 2-6 cells NiMH/NiCd Cells: 1~15 LiHVLiIon/LiPoly Cells: 1~6 Pb battery Voltage: 2~20v Weight: 270g This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, TURNIGY and any pack with a JST-XH adapter. Includes: 1. Accucell 6 80W Charger 2. XT60 with Banana connector Charging Cable (430mm) 3. XT60 with Banana connector Charging Cable (300mm) 4. XT60 with Alligator Clip Charging Cable |
Author: | MickeM [ Sun 06 Sep 2015, 18:20 ] |
Så vem köpte Oscars Decathlon? Är den kvar på Åland? |
Author: | MickeM [ Tue 08 Sep 2015, 20:46 ] |
*klick* Närmare 1 m högt!!! Kanske mer, hittade inte mått på höjden. |
Author: | Kamikaze [ Wed 16 Sep 2015, 06:32 ] |
I dag får jag hämta ut Little apple 50 |
Author: | Bernt [ Fri 18 Sep 2015, 17:43 ] |
Hörde att någon var sugen på ny bil, blir det mer RC grejer till fältet nu? |
Author: | Mr X [ Fri 18 Sep 2015, 21:58 ] |
Ja Micke har problem att få prylarna med sig. Själv tittar man på lite större bil |
Author: | Bernt [ Sat 19 Sep 2015, 07:30 ] |
Ja det finns bussar till salu så nog får han med sig rc-grejer till fältet men var skall han svänga? |
Author: | MickeM [ Sat 19 Sep 2015, 10:33 ] |
Pratar ni om mig? Buss ska väl inte behövas... i en annan tråd pratade jag om Yaken och införskaffande av ny bil, men nu kom jag på att jag ju har stora Cuben också, den är 2,5m lång och är väldigt hög. Så hm... |
Author: | MickeM [ Mon 21 Sep 2015, 19:35 ] |
Nu blir det intressant! Paket på väg från Vertical hobby. Registrering:21.9.2015 kl. 14:32:13 Ort:ESPOO 02210 Vikt: 0,00 kg Volym: 0 m3 Postförskottsbelopp: 0,00 Tror ni jag behöver hyra släp? |
Author: | Kobbeuffe [ Mon 21 Sep 2015, 19:46 ] |
MickeM wrote: Nu blir det intressant! Paket på väg från Vertical hobby. Registrering:21.9.2015 kl. 14:32:13 Ort:ESPOO 02210 Vikt: 0,00 kg Volym: 0 m3 Postförskottsbelopp: 0,00 Tror ni jag behöver hyra släp? Haha ska ja komma me firmabilen? Jag borde hinna via efter ditt bränsle i morgon iaf. Och jag har GPS, Naze32 och miniApm kablage i väska redan |
Author: | MickeM [ Mon 21 Sep 2015, 21:01 ] |
Kobbeuffe wrote: MickeM wrote: Nu blir det intressant! Paket på väg från Vertical hobby. Registrering:21.9.2015 kl. 14:32:13 Ort:ESPOO 02210 Vikt: 0,00 kg Volym: 0 m3 Postförskottsbelopp: 0,00 Tror ni jag behöver hyra släp? Haha ska ja komma me firmabilen? Jag borde hinna via efter ditt bränsle i morgon iaf. Och jag har GPS, Naze32 och miniApm kablage i väska redan Kanoners!!! =) |
Author: | MickeM [ Tue 22 Sep 2015, 21:19 ] |
Blev massiv beställning från 3 ställen. Och NU känner jag att jag inte behöver nån till multirotor. Och inte heller flyg eller helikopter heller. Inte förrän jag skrotat eller sålt några. SKÖNT!!! Hur kalasbra som helst. Och vintern är räddad sedan tidigare. |
Author: | Kobbeuffe [ Thu 24 Sep 2015, 12:46 ] |
Va in en sväng till Hobbylinna idag så nån lär bli glad Attachment: IMG_0157 [136571].JPG [ 125.89 KiB | Viewed 8295 times ] Köpte lite småskit när jag endå va där. Grabbens lilla quad flyger kanske igen Attachment: IMG_0158 [136573].JPG [ 171.9 KiB | Viewed 8295 times ] Å givetvis måsta jag å ägarn flyga lite En Yuneec Q500 4K Typhoon Förbannat lättflugen foto/videomaskin. behöver ingen träning alls för att flyga denna. Attachment: IMG_0155 [136569].JPG [ 227.85 KiB | Viewed 8295 times ] |
Author: | Kamikaze [ Mon 28 Sep 2015, 19:10 ] |
Nu kommer det en trainer på posten http://www.phoenixmodel.com/Product.aspx?ProductId=559 https://www.youtube.com/watch?t=10&v=Y4GYOvyhCsw Köpt i polen Den ska ha eldrift |
Author: | MickeM [ Mon 28 Sep 2015, 19:21 ] |
Jag hade ju en Above All 25-size trainer förut, vart tog den vägen...?! Med el. |
Page 11 of 12 | All times are UTC + 2 hours |
